Anyone else into RC rock crawling?
Did you try a gluetread patch?
The chunk is gone, I didn’t notice it until we were packing up to leave. The place where we were crawling had a lot of big chunks of concrete and I think it might’ve caught on some rebar or something, and there was a lot of fishing line that got wrapped around axles and maybe I caught a hook or something. I’m looking for a single J concepts rupture if anybody’s got one by chance.
Reactions: reddvltj and TerryD
WOOT!
It's about time someone offered a TJ/LJ based fairly accurate body!! I like the highlines and the trail cage... Who ever designed it was using their k-noodle!!!
I can't remember if I can shorten the wheel base on my Landrover TRX4 to fit though? I know the Bronco, Blazer, and Sport are all 12.3" and can be stretched out a little. The Land Rover sits at 12.75"
Reactions: TerryD and srimes
I've never painted a body. Which is why I have a 20 year old Scrambler body still on the shelf.
Anyway, I know I can get Impact Orange paint for my Jeep, what about custom (oem) colors for models?
It's been a LONG time since I painted a body, but somewhere in the depths of those memories is something telling me there is a way you can use automotive paint and get it to work instead of using the special lexan paints... I'll see if I can get ahold of a friend of mine that took great pleasure in doing custom paint on RC bodies.
Reactions: matkal
You can use OEM color automotive paint on the lexan body.
You need to wash it with dawn dish soap then use a scotch bright pad to lightly scratch the inside of the body that is going to be painted... You might want to mask off the windows for this process, be sure to replace it before painting.. Once done with the scotchbright pad wash with dawn again. Once you get that done let it dry completely then mask off anything you don't want painted with the body color. Spray thin light coats until the entire inside is completely covered and you can not see any light coming through the color. Then after letting the paint set up enough it's tacky but not dry, remove any masking tape for areas that you want a different color (leave the rest). Let the first color cure completely. Repeat the same process with light coats until no light comes through the paint. Repeat as necessary for other colors... Once your last color is cured, before you remove the remaining masking tape pic a good base color to use as an abrasion guard.
Here's a pic of a body he painted with automotive pain using that process...
Damn there's a LOT of hate going on in that post. I don't think it looks too bad. So they may have borrowed a little from their FJ body style, Toyota got that design cue from Jeep in the first place... BIG DEAL. Then there was the comment about the fenders.... LMAO someone has obviously never seen highlines on a TJ/LJ before. It makes me wonder if any of them have ever seen a true off road vehicle up close and personal, or are they all just 1/10th scale power flexers... 🤣
Reactions: srimes and matkal
It was the steering wheel that killed it for me.
Reactions: reddvltj
Wife got me this brush guard for my K10 for Christmas and for some reason gave it to me today.
Looks killer on there. Had to pull the Injora underdrive gears because of binding. Almost locking up in the front. It has their low transmission gearing and aluminum transmission case so it still crawls OK.
I have the Injora Fat Viper brushless 2000kv setup to go in once the replacement pinion gear arrives. That should make it great for walking/hiking and mild crawling.
The SCX24 C10 is waiting for a new set of wheels. I've also got the Injora Kangaroo SCX24 chassis and Deadbolt links ordered to start a new build.
I'm looking for a blue V2 Horizon ESC/Receiver if anyone would part with one. Gonna use my V1 from the C10 in the Kangaroo with a brushless setup of some form. The Komodo is on sale, may snatch up one of those.
