I just realized I don't have a single photo of my '97 TJ when it was new or still on its 30" tires. I'm shocked.Pics or it never happened to you too. I need to see JerryB with 30" tires on a Jeep. I don't believe it.
Because your Jeep looks like everyone elses stock Jeep.
Were those 3.75 gears a custom item?
Pretty sure all 4.0 automatics had 3.73 gears. You can also run a build sheet to check what it left the factory with.
Go here and enter your VIN. Once you do that, you'll see everything your Jeep had originally. That said, a 31" tire will be fine on your Jeep.
[URL]https://fcacommunity.force.com/RAM/s/equipment-listing[/URL]
FWIW, math is your friend here. A 235/75R15 tire is generally 28.8". A 31x10.50R15 tire is usually 30.5". If you run the gear calculator, assuming a 32RH automatic with 3.73 gears, you get:
28.8" tire = 3046 RPMs @ 70 mph
30.5" tire = 2876 RPMs @ 70 mph
That equals a 170 RPM difference between the two tires @ 70 mph. This is not a significant difference at all. Run a 31" tire and be happy!
Interesting. I've never seen a 3.07 automatic, but guess it could be something as simple as the factory ran out of 3.73 gears and wanted to keep production rolling!I was actually bored yesterday and searched a bunch of autotrader VINs from 97-02 to see what would happen. Majority of 32RH automatics were 3.73, though there were some 3.07s.
[URL][URL]https://fcacommunity.force.com/RAM/s/equipment-listing[/URL][/URL]
Now you have.Interesting. I've never seen a 3.07 automatic
Now you have.
p.s. Can you make my Jeep look as good as yours (for a discount) now.
p.p.s. The 3.07s (and 33s) are why I sold it. Luckily, I found my Rubicon 4 days later.
