Nice, I didn’t know about that one. I made the decision to get the 2971 after discovering
this thread and seeing that it looks similar to the Mopar. No idea if it works any better or worse than what you have or the 2771.
My system was pretty rusty when I bought the vehicle, so I do a thermocure flush about once a year. I’m currently running a higher ratio of coolant to see if it helps reduce the corrosion (and sufficiently cools).
The biggest cooling improvement came after I used the water/air gun to flush trash out of the system. I filled up about 20 totes with flushed water and bits were still coming out. About half way through the process, a bunch of nastiness was set free from the heater core causing the water to look it was round 1.
