Yes thank godDid it include the dipstick?
“Just got this for my dad.”Just picked up this 32rh with only 40k miles on it for my dad. Oil inside looked good. This is exciting for a few reasons. The first is obviously wheeling. A manual/231 combo just plain sucks to wheel out here. This is also going to make the Jeep street better because he currently has front driveshaft vibes at 70mph with 5.13 gears. We will gear down to 4.56 with the auto which should move his vibe onset more towards 80mphView attachment 327504
Don’t you have enough Jeeplinquents already?“Just got this for my dad.”
Can I be your dad?
Yeah, but no 32rh. if I did a swap, and if it’s possible for an 05’, that’s the one id prefer for gearing issuesDon’t you have enough Jeeplinquents already?
Its possible...but very difficult. I think @Lou did one. I was talked out of it by a wise wizard.Yeah, but no 32rh. if I did a swap, and if it’s possible for an 05’, that’s the one id prefer for gearing issues
Yeah he converted his 03 to an 02. It takes good wiring skills.Its possible...but very difficult. I think @Lou did one. I was talked out of it by a wise wizard.
I think that was the only way to keep the automatic torque converter lock up through the PCM. Otherwise, a manual switch needs to be used.Yeah he converted his 03 to an 02. It takes good wiring skills.
I was thinking a 42rle would be much easier for an 05' swap. Otherwise just buy an earlier model TJ with a 32rh. I've been known to buy TJ's. I'm a glutton for punishment. LOLIts possible...but very difficult. I think @Lou did one. I was talked out of it by a wise wizard.
I'll let you know in a month or so.I was thinking a 42rle would be much easier for an 05' swap. Otherwise just buy an earlier model TJ with a 32rh. I've been known to buy TJ's. I'm a glutton for punishment. LOL
Plug and play.I'll let you know in a month or so.
Unplug unplug unplug unplug unplug unplug unplug unplug unplug unplug unplug unplug, plug it all back in and play.Plug and play.
It's gonna be fun.Unplug unplug unplug unplug unplug unplug unplug unplug unplug unplug unplug unplug, plug it all back in and play.
What’s possible?Its possible...but very difficult. I think @Lou did one. I was talked out of it by a wise wizard.
Swapping a 32RH into an 05 with the NGC controller and doing it properly.What’s possible?
Not possible.Swapping a 32RH into an 05 with the NGC controller and doing it properly.
I just found a 42rle for $30. Yeah, really $30, but I dont' see any harnesses. I need to figure out what all I need for this swap besides some of the obvious.I'll let you know in a month or so.
Blaine gave a good bit of that here:I just found a 42rle for $30. Yeah, really $30, but I dont' see any harnesses. I need to figure out what all I need for this swap besides some of the obvious.
For the record, I sold my NSG370 for $800 ($950 if you include the PCM) with all of the swap parts to someone wanting to do an auto to manual swap. That covered the cost of all of the parts I needed to buy and what I spent on the engine/transmission donor, and I still have the engine to sell.I just found a 42rle for $30. Yeah, really $30, but I dont' see any harnesses. I need to figure out what all I need for this swap besides some of the obvious.
