How to not fuck up a shock outboard 101:
Step 1: Determine how much uptravel and downtravel you want. I want 6” up/6” down
Step 2: figure out how long that would make your shock at ride height.
Ex: If my extended shock length is 31 1/8”, and I’m splitting my travel 6” up and 6” down, then my shock at ride height will be 25 1/8” because the shocks will be compressed by 6”.
Step 3: Make a stick mock shock that is the ride height length center of eye to center of eye. The stick must have tubes that are the same ID as the shock eyes and the same width as the mounts. Be sure your little tubes are exactly 90* to the stick.
Then you get to bolt the stick in the mounts and it will be impossible to mess up your travel bias when mocking up the mounts on your Jeep. This is also important because not only will your bias be perfect, but the heim joints in the shocks will also be exactly neutral at ride height. This ensures you will not bind the joints at articulation.
As long as your fitment is done at design ride height. You mentioned it, it needs to be highly emphasized.
