Thought I’d provide a lil update.
While still trying to tame this beast and rooting around the whole suspension I noticed my rear anti sway bar axle bushings were sloppy so I replaced them. I feel like it helped a little bit with the rolling feeling.
I also replaced the Falcon Nexus steering stabilizer with a Blackmax. That feels to have tightened up the steering a wee bit. Although it could just be a placebo effect. Like when new windshield wipers make my Tundra go faster…
Next up will be replacing the Falcon shocks with Blackmax and replacing the front anti sway bar bushings. If the BlackMax shocks do nothing I will remove them and put them up for sale.
One question. Should the drag link/tie rod joint move back and forth? It has some roll to it when I rotate it to the front and the rear. I assume this is normal with no other play or slop.
Can we start over a bit? I watched your video a few times and I can't tell if you have one hand resting on the steering wheel or not? Which is it?
When I find that out, then I have a little test I want you to do for me that will help me figure out a few things.
