where/how much final welding did you end up doing?
The jounces won't do their job of helping slow down the last bit of travel before the shocks reach full compression.What are the consequences of not having the bumpstops lined up?
Yup... they tend to look like this after a SYE; even worse with a tummy tuck (like mine).What's the point of doing this? Straighten up the springs after raising the pinion?
Never have, but it would make some things easier.Did y’all remove the gas tank to do this job ? It’s mighty close when welding .?
If the mounts are lined up with the hole on the frame arch, then you probably did it rightWell I got a crazy Idea today. So I set out to move my Upper coil spring buckets.
So I have got them off and move them and compressed my axles. I think I have them where I want them. What ya think ?
Yep they are .If the mounts are lined up with the hole on the frame arch, then you probably did it right
Looking good.Well I got a crazy Idea today. So I set out to move my Upper coil spring buckets.
Aluminum foil also works wellLooking good.
Hate to be the Safety Police but no want to see a fellow Jeeper in an accident.
I do not remove the gas tank but protect the area with a welding blanket well, Sparks are not controllable and hot enough t melt anything does not tolerate heat. I use the chelo ones from HF, so far no issues.
Thanks for the safety headsup.Looking good.
Looks lined up. Exactly where I put mine. Glue em on!Well I got a crazy Idea today. So I set out to move my Upper coil spring buckets.
there is a top and a bottom to those. Just make sure they are the same both sides. I have mine with the end of the bottom coil facing to the rear. It shouldn't matterIs there a certain way the springs should locate?? I can turn mine 360deg. I’m sure they need to be the same. ????
Well the way my are located tops and bottoms , the end of the bottom coil , one would have to face to the back and one would have to face the front.there is a top and a bottom to those. Just make sure they are the same both sides. I have mine with the end of the bottom coil facing to the rear. It shouldn't matter
shouldn't be an issue. You will see ride height after and can measureWell the way my are located tops and bottoms , the end of the bottom coil , one would have to face to the back and one would have to face the front.
Rear springs don't have a top or bottom.there is a top and a bottom to those. Just make sure they are the same both sides. I have mine with the end of the bottom coil facing to the rear. It shouldn't matter
What I meant by that is, most rear coils will have stamped writing on it. I always put the writing right side up (top) to me. RE coils especially do. Maybe it is my OCD but I never put one coil with writing facing up, and the other one with writing facing downRear springs don't have a top or bottom.
