To start off, other than the noises, the tranny shifts well. No grinding or difficulty selecting gears. In neutral there's a knocking noise that goes away when I press the clutch in. I'm not sure what's making that noise but I'm thinking it's either an input shaft bearing or the throw out bearing is loose and rattling around. Then when in 3rd, 4th, and 5th, I can hear a higher pitch noise that gets louder as I increase the gear, assuming due to higher rpm. I'm wondering if this is any cause for concern. I've read about people with bad tranny bearings that had their bell housing crack due to bearings seizing up and twisting the tranny. It only has 139k miles on and I'm running redline in it. Here's a video to hear the noises.
