Long time Jeeper, took a few years off and now getting back into it. Last time out came home with the Angry Sparrows. Turned out to be the front DS Centering Yoke. I fixed that, however while searching for the noise I did discovered a little rattle (by hand) when I shake the front axle U-Joints (both). I assume this is not normal? If so, I will replace the axle u-joints. While I'm at it and have it all torn down, I figured I might as well replace the bearing units (Timken) as well. Now I'm thinking I should do the Ball Joints too? It a 1997, riding on 35's. The unit bearing and ball joints are stock from 1997. Fist of all, is the rattle by hand normal? If not I will replace, but should I replace everything else mentioned as well?
