Go away Johan!geek squad chat is a well-known tech service provider company in the world. Our experts offer support for all types of technical problems faced in computers, laptops and smartphones. They even provide solutions for home appliances, TV, smart wearable and home theatre. We help our customers in setup, installation, repair, uninstallation, replacement, damage and other issues. Our dedicated support team is always available at your service and assures you for the quick resolutions. Book geek squad chat today and get your device fixed without wasting much time.
geek squad chat
geek squad chat now
geek squad chat with an agent
I decided on the Rancho 5000x and have had them about a year now. They've been great. No experience with the other options mentioned. I do want to say wobble is more than likely worn Tie rod ends, bad caster because of lift and stock control arms, worn trac bar ends, or worn d-link end. Also I would check the torque on all bolts of the mention above ends.I tow my 05 stock TJ behind my RV. I'm going to start letting my 'better half' drive the jeep. Will be mostly So Cal freeways with all the crazy drivers.......I want to eliminate any wobble, etc at freeway speeds so I'm going to start with the shocks, then balance the wheels , etc. Do you think the Rancho 5000x are the best shocks for my dilemma?
I forgot my question: If you don't care about lift, is there a good compatible spring set that should go with the shocks to further improve the ride? Thanks.I understand the logic about leaving the boots off. Then why (I am almost afraid to ask) would the manufacturers put them on with the implied message that they are there to protect against what obviously becomes a problem...dirt, moisture?
Is it just for the Bling factor?
If they have a lower spring constant and longer free length, it will make a difference and keep the same ride height.Springs are mostly just to set ride height, changing them out wouldn’t make a meaningful difference.
No it won'tIf they have a lower spring constant and longer free length, it will make a difference and keep the same ride height.
Care to elaborate?
Shocks act long before a spring makes any meaningful impact, that’s their job (to control spring movement). They convert the kinetic energy into heat (typically). So no, the spring rate really doesn’t have a meaningful impact on ride, that example would just keep them in place longer before they unseat, assuming that’s valid for the rig’s available travel.
