Thanks
@qslim for explaining out this diagram, seriously helped a ton with troubleshooting. I'm gonna quickly go over how I narrowed it down to the ground.
I like it when there is a step-by-step guide to troubleshooting things like this, but I couldn't find one for the blower not working at any speed. Because of this, I am going to take a stab at doing it on my own.
Also, please tell me if I misinterpreted where the blower motor is in this diagram. I think I got it right though.
NOTE: This is the fuse diagram for the 1998 model year, and the fuse numbers I use are the ones for that version. I believe it is the same for 1997 as well but I believe it changed in 1999. The same general way that the system works should be the same, but fuse/relay locations etc. may be different.
Check this thread to find the diagram for your exact model year.
First, I checked where I put the red checkmarks, which are the 20a fuse #8 behind the glove box and the 40a fuse #11 in the engine bay. Those weren't popped and I used a voltmeter just to make sure.
The next easiest thing to check is the blower motor relay next to the green checkmark. That is also behind the glove box, closer to the right side. I knew that worked because I heard it actuate when I changed the slider setting from off to front vents. Just to be sure, I swapped it with a known working one. A couple of the relays in the PDC in the engine bay are the same kind of relay. I used my rear defrost relay, but the ABS relay (if you're equipped with it) or the starter relay should work as well.
The next was the actual fan speed control switch, next to the blue checkmark. The connector has letters on it that tell you what each connector is. I jumped C to any of the other ones, and the fan would not spin. Plugging the connector back in and cycling through the speeds like normal, still nothing. To test that the switch wasn't working, I put a voltmeter on both pins of the blower fan connector and cycled through. I was reading about 4 volts on the highest setting and it got lower each step I turned the switch, leading me to believe that the switch worked.
After that, the next thing to test would be the relay, although if that were the issue the highest fan speed should still work, which was not the case for me. Regardless, I tested it out. I happened to have a new one when I accidentally bought two and I simply replaced it. I believe there is a way to test it using the voltmeter on the ohm setting, but I do not know exact values etc. However, it is about a $10 part at most that fails commonly, so may as well replace it while you are there.
The last thing to test was the actual blower motor itself. To remove it, first disconnect at remove the battery. Next, remove the three (3) 8mm bolts holding in the PCM and remove the plugs. Last, use the same 8mm socket to remove the 3 shorter bolts holding in the blower fan. You are probably going to want an extension for this. To manually jump it, stick two spade connectors into the terminals inside the blower fan, and touch them to the battery, try to swap the polarity if it doesn't work the first time. If it does work, you will probably cause a spark and scare the hell out of you before starting to spin, but if it doesn't, nothing happens. The latter was the case for me. I bought an admittedly very expensive (to me, $100) blower motor and replaced it. As other people wrote in some other posts on this thread, you can get it on RockAuto or Ebay for much cheaper, but I really needed it then and there; it was about 95 degrees outside and 85% humidity. That still, however, didn't fix the problem.
That meant that all the individual components were good, and it was a wire in between one of them that was the issue. The only thing from the relay worked, which means that the resistor worked, which means that the fan speed switch worked. I just replaced the motor, so that was good.
I ended up finding out that if I were to put the voltmeter's positive lead on the blower motor fan connector and the negative lead onto the negative side of the battery, I was reading a full 12 volts. Doing the same on the going into the connector going into the blower motor was reading about 4 volts. Turns out that when the PO cut the original connector in favor of spade connectors (?) he did not do a good job of securing the connector for the ground cable. It was loose and making an intermittent connection. Fixed it up and now the fan works perfectly!
