Have 05 LJ auto to build, 98 TJ 5 speed to use for parts, 5.3 LS with 4l60e. Have titles for both.
What will be easier, cheaper and better to build:?
1) 5.3 with 4l60e into the LJ
2) 5.3 with Ax15 from TJ into the LJ
You're doing so much work, what do you WANT to build? If it were me, It would be the LJ, for sure.
Come on man, you’re supposed to say “autos are better”
Well, they are. Is it even a discussion at this point?![]()
Based on his question, yes
Auto being better makes easier and cheaper not as important.
Try to weigh on 4l60e or ax15 base on others experience
Based on not having done that specifically but just about everything else connected, I suspect you'll have to find a way to adapt the CPS to run off of the GM PCM. If you do the GM/GM swap, that should inherently be part of that specific LS harness with no adapting needed other than what it would take to interface it with the TJ body harness for the gauges and whatnot depending on the route you go, adapted OEM gauges or new gauge set.
Easier would be GM/GM into the TJ, easiest would be to swap over the TJ 4.0, TJ trans, TJ harness and get that all working. When that is done, then do the motor swap.
Yes the LJ, but with 4l60e or ax15?
As far as the swap goes, there is no fundamental difference between the TJ and TJ Unlimited. From the end of the t-case forward to the grill, they are identical in all respects and the only difference that would concern you is extending a brake line, fuel pump harness, and driveshaft.The TJ will be just for parts, did you mean GM/GM into the LJ?
Plug and play. Except for the longer bits mentioned above.Wondering why would it be easiest to move the TJ engine/tran into the LJ?
For the VIN challenged, we'll see who is paying attention. This is a new door jamb VIN sticker that needs replaced. See if you can spot why.
old
new
Looks like a color change, red to black
Orange to black but nothing else.
Oops looked more red on my computer. It does look orange on my phone.
You're going to want the 4.88s but you'll also want the Dana 44 unless the 35 is a super 35.
