Can't shift gears
Hey there I'm stuck with this issue now with the Jeep on or off I can't shift into any gear simply stuck in neutral. Change the master salve and it did not solve my issue. It's at the shop now and the tech is convinced I need a trans swap.
I'm open to all recommendations.
If changing the master and slave cylinder didn't fix the issue, it's possible that there is a problem with the transmission itself. However, before going ahead with a transmission swap, it might be helpful to get a second opinion from another mechanic or specialist who is experienced with Jeeps. They may be able to diagnose the problem more accurately and potentially offer alternative solutions. I
Yepp that’s the plan jeep specialist is heading to the shop where it’s at.
