CB Radio
TJ John
Lebanon, MO, United States
I have a CB Radio from when I Drive over the road and it pretty big. I want to install it in my Jeep TJ. BUT, I can't figure out where and how to mount it.
Any ideas?
Sent from my SM-G900V using Tapatalk
I put mine on top of the dash over top of the stereo.. It is a full size radio and isn't in my way. Then I ordered a mount for the antenna from Arizon Rocky Road that bolts to the center of the tailgate.
Thanks. But I need room for the cooling fins to do there job. This is a 300 to 400 watt radio. Those fins get so hot you could get a blister if you touched them. Not that I'm going to be using it at full power all the time but it's a big radio Physically and power output wise.
I thought about putting it on the back of the center console between the two seats or above the windshield but I need to come up with some kind of a mounting bracket.
I hate to be an AH on CB radios that put out illegal amounts of power like that but, well, I will be. This is because of how many times CBs running illegal amounts of power have interfered with or sometimes even blocked my legal use of the CB band.
I get so pissed off when one of those goes on the air, they put out enough power to splatter across multiple CB channels and stop anyone from trying to legally use a channel even close to the channel the illegal transmitter is on. I have had to move 20 channels away from some CB users just to be able to use my CB.
The more power an AM transmitter puts out, the wider its signal. That's where the problem is with a CB with an illegal amount of power, its wider signal. CB channels are so close together that the power a transmitter can put out has to be limited so everyone can use all 40 channels. We had one local AH who would follow us up & down the CB band with his 300 watt CB linear amp so we couldn't talk anywhere.
The CB's narrow channel layout in the US is the reason CB AM transmitters in the US are limited to a max of 4 watts. And SSB is not much more than that at 12 watts PEP maximum power allowed. I'd chase anyone out of any group I was leading if they were trying to use a CB like that. Not to mention that radio is 100% illegal for use in the US, even if its power was turned down.
I run big power on my ham radios because it's legal and we're not restricted to channels. But when I'm using my CB, its 4 legal watts is plenty.
AH mode off. For now. ;)
Illegal? yes and no. the reason i was able to buy this radio brand new just like this, is because it's not just an 11-meter band radio it's also a 10 meter band radio "ham radio". So it's only illegal if I crank up the power on 11 meter band. I checked into it before I bought it. The only time I ever Crank It Up on the 11 meter side was when some a-hole would interrupted by conversation.. if you've ever driven over the road you would know there's a lot of AH out there. I also have the power dial marked where it's legal for 11 meter band.
I shouldn't have to defend myself but it sure sounds like you're accusing me of being an a-hole based on the radio that I have not based on how i use it.
Reactions: BendLarry
Ok but those radios are still 100% absolutely illegal for use here in the US because of their power, that they can also transmit on 10m, and that they are not 'type certified'. I've made my point I'm done here. :)
I'm not really sure why you commented on my post in the first place. if you look at my original post I was looking for opinions on how and where to mount the radio I was not looking for opinions about my radio.But Thanks for your opinion anyways.
I gave my unsolicited opinion for 3 reasons... 1) Not everyone knows such a radio is illegal for use here in the US. 2) Not everyone understands (cares?) the technical reasons why they are illegal for use here in the US. 3) Because I've run into too many of them causing problems out where I wheel. Because of the many problems they have caused me personally over many years, I am just a little more sensitive about their use here in the US than some may like or understand why I choose to be an AH on that one subject.
Most would agree being an AH is not my usual mode here. :)
Reactions: TimB54 and StG58
Anyways, back on-topic here, I'd check out the Arizona Rocky Road CB Radio Mount. With that mount you gain a way to not only mount your CB radio, but also anything else you'd like to mount up there as well.
I agree, that is a very good no-drill mount that works well at supporting even multiple radios.
Reactions: Chris and StG58
I understand where you are coming from. That's why I don't have a CB Radio in my road truck anymore. I haven't had one for about 4 years now. I just got fed up with all the AH's on the radio that think since they're having a bad day they feel the need to make everyone else's day a bad one too. I'm so tired listing to all the hatred, racist and sexist comments. Until you start driving over the road with a CD you have no idea how much of this goes on. it's amazing Society has made it this far. You Can't listen to that all day everyday without being affected. I'm hoping that Jeepers are a higher class of people so I can use my radio again. I wouldn't mind getting a 4 watt radio. I just don't see the need to buy another radio when I already have one. Just because someone has powerful radio don't make them an AH. I'm not like that. I just thought it would be nice to talk to other Jeepers and this is what I have available to me.
