Guilty, as-charged!Well...your threads do have a tendency to go 'offroad', shall we say...:abrazo:
Wow,
Interesting how many folks are adamant about must have this or that. I guess that’s the power of the internet.
I have two Jeeps, a manual 6 speed 2006 LJ Rubi with 35s and 4.56 gears and an auto 2004 TJ with 33s and 3.73s. I’ve also swapped tires and gears on these Jeeps. The 35/4.56 combo is almost exactly the same as stock tires and 4.10s. The 33/3.73 combo is surely a taller ratio but one that I find acceptable if you don’t mind dropping out of OD to accelerate, pass, or go up an incline.
I also have a spreadsheet I made that allows one to input any transmission, axle ratio, and speed. Some of the info being thrown around this thread is a little loose. Figure out what is acceptable, what you have for goals and run the numbers. Taking some of the advice being dished out here is unlikely to make you happy. Only a few of the folks throwing out recommendations have even considered the very large differences between final drive ratio variations between a 6 speed, 5 speed, and auto.
I find the 4.56/35” combo pretty close to ideal for my 6 speed. I can always drop down to 5th but rarely need to during normal freeway driving. I had 5.13s in the rear end before it was installed in my Jeep, I paid good money to switch to 4.56s. I did my homework myself and I’m happy with my choice. My Jeep cruises comfortably at 75, it wouldn’t if it had a 5.13.
Wow,
It works for you. That's all that matters.It’s nice to see there is more than one answer to the 33 tire gear ratio issue!
My posts on the matter were soundly dismissed.
Low gears are better both on and off road. There is no downside. You are trying to convince yourself that poor performance is normal for a Jeep. It doesn't need to be that way.
Not to mention finding a shop that can do it right and stands behind their work.It's not that easy for most people. Not everyone has the technical know-how to swap out their gears or the money to pay someone else to do it.
True but, it is all part of the building process. People have no issue dropping a few grand for a lift or on wheels and tires but choke on a 1600 dollar gear swap. It is easier to spend big bucks on something you can physically see as opposed to something hidden by a diff cover.It's not that easy for most people. Not everyone has the technical know-how to swap out their gears or the money to pay someone else to do it.
That has nothing to do with the validity of the advice. Pretending that being undergeared is perfectly fine with any qualification is doing everyone a disservice.It's not that easy for most people. Not everyone has the technical know-how to swap out their gears or the money to pay someone else to do it.
Jeffreybomb said:A gear swap should be on everyone's list if they want to make the most of their lift and wheels.
I said exactly the opposite of what you're claiming I did in a later comment:
"Doing a disservice" is firing off an ill-advised rebuke.
I got the same kind of replies from this guy. Do what’s right for you. He can go pound sand.
How is THAT helping the OP?
IMHO the OP is best served by knowing all the options.
