I'm currently on the hunt for some axles. Pretty much everything I've seen has surface rust to some extent. I've read about sandblasting; it sounds like that's a good option to go with as far as getting the axles cleaned up.
I know it's a pretty messy process. Is there anything I should be aware of when I drop off a set of axles? Should the sandblasting company know how to clean them off without causing future problems when I get the axles together? Do I need to strip the axles down of the components I plan to eventually replace, or is it a better idea to leave them in as protection to the interior?
