Looking for a little direction here. I have a 2004 TJ 4.0 with 42rle and Dana 44 rear. 2 inch spring spacer lift. RHD.
I have been trying to track down this noise coming from the rear end. These things are all new, upper and lower control arms, shocks, sway bars. Drums and brakes. Drive shaft. I’ve drained and cleaned the differential. Refilled with 75w140 with the diff additive.
The knocking/ cricking is somewhat what rhythmic. I only seem to hear it at low speeds, like a parking lot. Generally only with the wheels slightly turned. Only hear it when going straight every now and then at slow speeds. If it’s happening at higher speeds it’s not noticeable. Today I removed the rear drive shaft and drove around. The noise wasn’t the same, but it was very slightly noticeable. It seems like the drive shaft or the load make it louder.
Any direction or advice would be greatly appreciated. I attached a video of the sound.
