Old radiator is out (gross!) and I have a couple quick questions as set the new one back up.
1) Should I be concerned about air in the transmission cooling lines to/from the new radiator? I lost a bit of fluid when I pulled them but nothing that I can't top off with the little bit of MOPAR ATF 4 I have on hand. Don't know anything about burping trans cooling system nor have I seen anything about it.
2) I saved all the coolant I drained from the old radiator since I literally just did the rest of the system last weekend and will just dump it in and fill the new radiator. Just so I'm clear, pour first gallon premixed into radiator. Start Jeep, and add second gallon leftover mix a bit at a time. At this point, I would presumably have the front end already jacked up to burp it, right?
3) Should I wait to top off trans with ATF 4 until after I've burped the cooling system? Can't see why it'd be a big deal to do it same time but anything with the trans always has me nervous
4) Anything else I should be aware of? As far as I can tell, put the radiator back in and bolt it up, reattach upper/lower rad hoses, in/out auto trans coolant lines, begin filling and basically follow same process as when I replaced water pump etc...
