Ah, looking back I think I misread where you said you installed the PSC kit (I thought you said you purchased the kit but have not yet installed - hence my shock of you not having any issues with 35"s!). It's interesting to hear your results, I assume it's the standard bore PSC box that comes in their "budget" kit?All of my wheeling has been East Coast. However, that has involved sand, mud, tight woods, and big rocks. I also run locked front and rear, and run beadlocks between 8 - 10 psi. With the factory steering box/pump it got to the point where I couldn't turn the wheel while crawling over a big rock. I added the PSC box and pump, and
With this combination, and a 35" tire, I haven't seen the need to add the assist yet. Frankly, I'm shocked that the pump doesn't even groan when under stress. Perhaps it's because I spent a ridiculous amount of time ensuring my lines were as short and direct as possible, and bleeding the system by hand before I started it the first time.
- -12AN feed line to the pump
- -8AN return line
- -8AN 16" Single Pass heat sink cooler
Edit: The steering is smooth as can be at speed and I have no return to center issues. Also, I'd have to say this is probably my favorite modification. It's that good from my perspective!
Speaking of pump noise, I wonder if I need to give PSC a call. Mine makes zero noise on the trail, with or without the locker on, or anything related to turning the tires. It does have a small whine at high engine RPM, which I just assumed was inherent with the increased pump output, but perhaps I need to follow-up (I too was meticulous about bleeding and routing!).
