Follow up on my EGR issue. The Cummins repair site called Quickserve lists out that continuing to drive with the egr fault code can result in the ECM reducing max engine torque. I contacted Brittany, the tech lead at Cummins and she replied back that on this model, the EGR will fail closed with this code, I got an easy EGR delete, keep that nasty exhaust out of my intake tract!
My next question for you guys is should I turn up the power on this engine? Tuners are getting scarce because of the EPA cracking down and leveling big fines. But I think there is at least one person willing to tune my ECM with a 200 hp/400 ft lb tune, the big question is can my AX15 live with 400 ft lbs of torque that comes on at 1800 and lasts through 2800 rpms. When I get on the highway, I am in 5th gear by 45 miles an hour and the Jeep pulls minor hills with ease, hills that the 4.0 gasser would have had to downshift to 4th on. Fuel economy so far seems excellent at over 20 mpg. My fuel gauge only reads 90% when the tank is totally full, but it gives me a reference. I have been driving the Jeep to an appointment 40 miles from home and I have made the trip 3 times to try and get some miles on it. My mechanical fan set up is 10 times better than the POS supposed 3000 cfm electric fan and shroud that I put on originally. This thing is kind of fun to drive and if I bang through the gears at WOT, it would easily out accelerate my old 4.0. Engine is pretty quiet even with the 2.5 inch stainless straight pipe exhaust! I would say my 4.56 gears are perfect for my type of driving.
Sorry to reply to this old post but I have the R2.8 as well. I’ve been wanting to delete the egr as well as getting it tuned. I was curious if you ever did and how it’s running so far afterwards. And did you just send in your ecm to get flashed or did you put it on a dyno and tune it that way? Thanks in advance! Texting me would probably be easier if you’d like. 541-six0three-8two5one
