Good tip! I have already designed openings for the fuel tank skid bolts. Something like this:Watch the wrap on the bottom. You can wrap where it bolts through to the frame, but you have to leave it open where the cross member is. That is where the fuel tank skid bolts down.
Also...I didn't hear anything from you after I sent that CAD file... Did it work out for you?
I didn't leave it open, since I think it will be stronger this way.
You are right! I should have mentioned your Autocad file above! It was helpful. I removed my bumper to measure myself as well, but it was helpful to have some other measurements to compare as well. Thanks again!
