I do have a tire groover...
Maybe a nice racing stripe down the middle would make it less obvious.
Balanced OK first try?
I know the MTR's aren't directional but having the driver's side one way and the passenger side the other would irk me Maybe it is just the picture.
I'd actually find out how they work first.I would start with some light siping right down the middle 2 tread blocks
What wheels are those? They look nice.Something else I had them do was install short valve stems.
Woops!They aren't directional but that drivers side front is not correct. They are supposed to be mounted like the passenger side.
Edit: that picture was deceiving... They are correct.
You'll read about it. I have expectations of the good and bad because @tworley has been daily driving his for the last few years in the same environments.I'll be interested to hear your review of the MTR's come this winter. My treps are garbage and need to get off the Jeep. While I'm partial towards the KM series BFG's, I might lean towards some MTR's if they are alright on the road and in the snow. I rarely drive in the snow but I need tires that can do so. During my trip to Wyoming in March 2019 I was being passed by semi's on a two lane road because my Treps couldn't get any traction. If you have some good experiences in the snow I'd probably swap some MTR's on come this spring.
Or Patagonia's!I have a feeling the MTR's will be my next tire (maybe even in a 33 rather than a 35!). I grew up driving in the snow. Driving from Jackson, Wyoming to Rock Springs during a light snow on my trepadors had my knuckles whiter than they've ever been before. I could not believe the lack of traction that the treps gave me. l got duped into buying these things due to positive reviews. Maybe just like people who have PS rock sliders
Lucky the flare didn’t hit someone. Never considered that happening.Enough time has passed that I think this is safe to talk about.
Since the rear MCE flares went on this spring, they have fallen off multiple times. Several times on the trail when I rub against a tree or a rock, as designed and a reason why I wanted them. However, the rear driver's side has blown off three times on the highway. Once I found it, twice it was gone forever. MCE sent me a replacement both times. That's great, but I really don't like driving around with a missing flare.
This time I made a small change to the top two mounting posts.
Using the extra replacement MCE hardware, I added an extra washer to the top of the post.
This means the flare and it's rubber grommet will need to pull past the washer in order to fully detach. The lower section can still break free like the fronts do. But a much stronger pull is needed to remove the flare. I've been driving with these extra washers for about 2 weeks with no signs of the flare wanting to fly away.
