The front mount for the magnets is attached. Halfway done!
That's pretty slick!
The under hood lights have been on hold due to weather and life and nice batteries dying a young death.
Last week Thursday, I decided to drive the Jeep into work and noticed a slightly slow starter upon start up after unplugging the trickle charger. At the end of the day, the battery was dead with only clicks. I got a jump start and drove home and plugged in the trickle charger. Friday afternoon, the battery was dead again.
This battery was an Advance Auto re-release of the Diehard Platinum from June 2021. It lived 3.5 years despite being plugged in almost every night and day that it wasn't on the road.
It seems Advance no longer has a group 34 DH Platinum available. So, I ordered an Odyssey Extreme from Napa that took all week to ship via UPS.
Something that has changed on the Odyssey since my last one died is that the terminals are brass instead of lead.
This is the fourth AGM battery in ten years, with an average lifespan of about 3.3333 years. I'll be doing this again summer of 2028.
What kind of trickle charger are you using on them? AGM specific?
A 1.5amp Schumacher thing. I have a new 2amp NoCo charger for AGMs that I will install in the near future.
I'm not sure it matters because the first DH Platinum never had a trickle charger and the first Odyssey didn't get one until a halfway through it's life.
They all lasted about the same amount.
..., are you sure you don't have some issue with your charging system?
How would I know?
Start by checking your charging voltage. And I haven't looked but there is probably some diagnostic procedures in the FSM. If my battery was dying that frequently, I would suspect the alternator or voltage regulator since you've sort of ruled out the trickle charger.
I know I've read where some with certain years install a separate voltage regulator because the PCM does it not so well in some cases. On my '05, I believe the regulator is built into the alternator. I've never had an issue with batteries dying. I put the Odyssey in when I first got the Jeep. I've been thinking it might be time for a new one just based on the age but it shows no signs of failing.
How is your voltage regulator configured? How old is your alternator?
It’s in the PCM, and there is at least one thread on here noting that the charging voltage is too low for AGMs. HPTuners allows you to change that charging voltage. I have HPTuners, but my LJ is not even close to drivable right now, so I haven’t tried that, yet. I did have a NorthStar that lasted only six months, so I’m keen to try upping the voltage.On my '05, I believe the regulator is built into the alternator.
FWIW, mine does have the sensor.
AGM max charging voltage is around 14.6, 14.7 for the AGM batteries I've seen specs for but that's only part of the story. If 14.6 is maintained after bulk charge has completed, it would beovercharging..
This is feeling like it requires data logging while knowing what things are supposed to look like in order to identity if there is a problem to be solved there.
IIRC, that is also tied into the random nature of whether or not there is a battery temp sensor installed. Around 05-06, they do and don't have them regardless of any other parameter. Without the sensor, the charge voltage is fixed and at a less than ideal rate. (IIRC)
…, yet.
I have the same issue as you, JJ. I can’t get an AGM to last longer than about 3 years - and sometimes not even 2. And I’m in the South, not nearly your cold temperature extremes. I originally thought it was the much discussed issue with the Mexico produced Optimas, but now I have gone through an Odyssey Extreme in under three years, and now on my second.
