How long was the jks Butt Crack on for it to compress or was the compression done with torque of the Butt Crack?
I joined the bent Currie tie rod club today!
I'm aware. The tie rod did what it is supposed to do.I’m sure you know but bending that tie rod probably saved you from breaking other things...Blaine has mentioned that regarding savvy’s version.
That photo reminds me of the how off chamber before I flip thread a week or so back. Off camber is still the one thing I haven't got used to yet. Were you winching up because you started to slide down?
Great photo.
Didn't notice a thing. The bend is enough to let the tie rod and track bar touch when the suspension compresses. But I only noticed that while going fast off road. I'll need to push the axle forward a hair until I can fix the tie rod. Which leads to a vibe update.I love that photo.
Do you feel anything wonky driving with the bent tie rod?
It is.This may be where I bent the tie rod.
Your tires aren't helping much either. As for your water solution. Get 1 5 gallon bladder and secure it on top of the inner fender in the back with a simple lightweight rack, or 2 2.5 gallon versions and put one on each fender. They don't slosh when partially full, fold them up when empty, easy to use on site.This is what driving by feel gets me.
