That is the factory mount.How were you able to move the tire so close?
I must have been extremely lucky when I removed my stock hinges to install the Exogate. I didn't use any heat and they broke free without much resistance.This is what the paint looks like after 15-20 seconds of MAP gas to soften the factory thread lock. Heat one bolt. Heat a second. Go back to the first after the heat has soaked in a bit.
The far left is what happens when you get impatient and don't use heat first. Fortunately there was even tooth left to unscrew after the heat.
The Jeep rides differently. It's difficult to say how, just different. The roll might be less in turns. The spare sits a bit lower than what I'm used to, which is nice for visibly. I have one of the Swiss water bags filled with 35lbs of water sitting in the very back to mimic the Swag bumper I intend to get.
They're useful, aren't they?
You will appreciate the difference on the trail unless you are oblivious which I don't think is the case. In fact, I wouldn't be surprised if you wonder why it took as long as it did to get that swing set off of there.The Jeep rides differently. It's difficult to say how, just different. The roll might be less in turns. The spare sits a bit lower than what I'm used to, which is nice for visibly. I have one of the Swiss water bags filled with 35lbs of water sitting in the very back to mimic the Swag bumper I intend to get.
I don't wheel where you do.Little off topic, but what is your recommended way of carrying a 35 or 37? I saw in a thread a long time ago that you might not like the OR fab carrier that I run. Is pulling it off the gate and putting it in the trunk the best way?
Some carry spares, some don't. Few are on the tailgate. Mine is on the trailer.I’ll be wheeling in the mountains or JV when I finally graduate and move back west. What’s the best way to carry a spare for that? Is the JV rule just run no spare?
Getting the tires balanced again. The guy at Discount had never seen wheel weights moved and spread across the wheel like mine were!
Here is the old carrier and bumper.
And this is stock. The Exogate shouldn't change this very much, plus I know I now have the ability to pull any tire really close in to the body. The Swag Big Hit will occupy a bit more space than nothing, but it will still be a significant improvement!
To put that in perspective, I made a lot of changes to the rig I take to JV once and ran short on time to come up with a tire solution for the new 37's. I snagged what was at the time, the state of the art Currie rear bumper and tire carrier. I already ran their front and rear bumpers previous so getting one with a swing out on it seemed fast and easy. Upon arriving in JV and running one trail, it upset the balance and the way the rig worked so much that I removed the tire and swing out portion when we got back to camp that day. It lasted exactly one trail.I'm excited about this next set of changes. I would like to get out with this one change and try a couple spots where I wondered if the weight, CoG and distribution were working against me.
I haven't seen their product but whatever one you get, it needs to wrap under the stock crossmember like the one from SWAG does. If you don't do that, the rear crossmember is subject to damage and will collapse. The lower flange gets smacked upward bad enough that you can't get a gas tank skid mounted back up just from hits on the stock tank skid.Slight change of plans. I've been pondering the hitch modifications that would bury the receiver into the rear cross member. I don't need all the extra stuff that SWAG includes. Next Venture is the cheapest option for a simple plate, especially with their FoJ sale. From there, I'll make my own receiver and French it in to the bumper and crossmember.
Now I just need to figure out why they can't ship to Colorado...
I've got a Genright one laying in the driveway that doesn't. It was too much to add to it so the owner got the one from Poison Spyder. As for the hitch. The one I did was on a TJ Unlimited. There is room back there between the two rear crossmembers to put the hitch receiver tube in nearly flush and reach up and access the pin between them. You don't have that option so it will have to stick out far enough to get the pin hole accessible or you're going to be modifying all the bits you want to stick into the receiver to move the holes to line up.I've been watching for that detail. Most of the ones I've looked at have the wrap around.
