I started using a MIDI fuse as an auxiliary post. https://www.amazon.com/LITTELFUSE-02981001ZXT-FUSE-HOLDER-piece/dp/B0195UTU6U/?tag=wranglerorg-20
Is this your buddy?
No, he drives an extra wide older Suburban with a big ole Detroit Diesel motor out of a garbage truck riding on concrete truck Super Singles. Front winch is a 20,000 lb. PTO driven that does not look out place.
The fix is to run a jumper wire from the headlight ground to the horn mount. Now I have four horns again!
The SwitchPros control panel is going here...
Included in the kit is a stainless steel mounting plate for the under hood controller. I cut it up for this instead.
Many hours, one dumb mistake and two trips to the hardware store later, this is it.
Halfway done!
I love the magic marker bluing trick. I’ve used that one myself.
Nice work, JJ.
What’s the trick?
Looking forward to how you mount the controller, (since you cut the plate up)
I finally committed to not subscribing to XM radio any time soon.
I left when half their radios in OEM cars couldn’t access all their channels. I found a stubby USB drive loaded with backup music hits the mark for out-of-service trail rides
Halfway done!
