Hello everyone. I’m sure this issue has been posted several times over again and I apologize for having to bring this up after all the knowledge you guys have given, but I need to talk to you guys because I’m really stuck with my death wobble issues and have been for quite a while now and I think yaw could give me some good advice.
I drive an 04 wrangler 2 door and I just recently installed an RC 4 inch lift which has now spawned my death wobble issues. Normally around 45-55 Mph it will start happening after the first bump I come across. I’ve read several forums about looking at different parts and checking for play/loose components. So I purchased an adjustable rubicon express front track bar, tie rod, tie rod ends, and a drag link. I bolted the track bar down to spec ( and before I checked the hole to see if it was wallowed out. There appears to be no play ). My father gave it an alignment, and will set the toe tomorrow morning at his work. If that does not settle my DW then I’m not to sure what will. Any help and advice is seriously appreciated. Thank you a bunch.
-Tanner.
-Tanner.
