H hawg New Member Original poster Joined Apr 24, 2021 Messages 7 Location melville May 10, 2021 #1 I am using the marking of the rotor method to replace distributor. Can I safely use a screwdriver to move the oil pump slot into position to drop in distributor or will this cause a problem. thks.
JKP TJ Expert Supporting Member Joined Aug 20, 2020 Messages 3,080 Location Warner Robins GA May 10, 2021 #2 A clean large screwdriver is what you are supposed to use.
H hawg New Member Original poster Joined Apr 24, 2021 Messages 7 Location melville May 10, 2021 #3 this movement wont cause any timing issues etc.? Pardon my ignorance.
JKP TJ Expert Supporting Member Joined Aug 20, 2020 Messages 3,080 Location Warner Robins GA May 10, 2021 #4 No. Oil pump has nothing to do with timing.
JKP TJ Expert Supporting Member Joined Aug 20, 2020 Messages 3,080 Location Warner Robins GA May 10, 2021 #5 You can download the FSM for your Jeep under Resources on this site which has the procedure in it.
H hawg New Member Original poster Joined Apr 24, 2021 Messages 7 Location melville May 10, 2021 #6 Thanks.
