Kenneth G Zinis
Thanks JerryCorrect, but aim the pinion up directly in line with the driveshaft so it's pointing directly at the CV joint.
TurboTJ, Do you mean the slip yoke on transmission or the slip joint on DS? I have SYEBe careful shortening the lower arms. I installed a TW double Cardan driveshaft and the slip joint would stack if the lower arms were shortened at all. I think the driveshaft should actually be a little shorter than it is.
I mean the slip joint in the driveshaft. I have a Rubicon so I did not need to install an SYE. I just replaced the driveshaft with the TW double Cardan shaft designed for the TJR. When rotating the pinion, it had to be done by lengthening the upper arms only. Shortening the lower arms even a little bit caused the driveshaft slip joint to stack.TurboTJ, Do you mean the slip yoke on transmission or the slip joint on DS? I have SYE
@TurboTJ How long are your LCAs?
Thanks Turbo TJ, great info that I'll followI mean the slip joint in the driveshaft. I have a Rubicon so I did not need to install an SYE. I just replaced the driveshaft with the TW double Cardan shaft designed for the TJR. When rotating the pinion, it had to be done by lengthening the upper arms only. Shortening the lower arms even a little bit caused the driveshaft slip joint to stack.
Thanks so much Mike_H@Kenneth G Zinis, If you want to know how long to set your lowers, you can go through a whole process. The short version is to pull your springs, jounce bumpers and and upper CA's ( at least one end). Use a jack to put the axle at full bump. Adjust bumpstop if necessary (it might be, depending on who installed your lift). Set your lower CAs so that the axle pad is centered on the frame bumpstop. Now check the ensure the axle is square to the frame. Make adjustments to the lowers until it is square. They should be minor, if you centered the bumps carefully.
Now set pinion angle. Should be done with the weight of the car on the axle... So put your springs back in. Use a jack to get pinion angle correct, then adjust and install your upper arms to the correct length. They most likely will not be the same, side to side. That is ok. The bolts should slide in and out easily.
Long post, and I left out a bunch of details. This isn't a trivial thing to do, though it's not hard, per se. Just time consuming.
Do I need a 1" drop for my 01 to because of the factory shaft and the front seal on the front of MTV transfer case? I did the rear. I have a 4" liftYes, it's absolutely necessary unless you want to destroy your driveshaft and transfer case.
Unless you have a SYE, double cardan driveshaft, and adjustable rear control arms.
I can’t tell you how much of a transfer case drop you’ll need, but I can tell you that you need one for sure for 4 inches of lift. It’s just going to be a matter of experimenting with different heights of transfer case drops to see how much it takes to get vibration free.Do I need a 1" drop for my 01 to because of the factory shaft and the front seal on the front of MTV transfer case? I did the rear. I have a 4" lift
Good thinking, a 1" motor mount lift works just as well as a 1" tcase drop.Just thinking out loud here, and I’m new to jeeps so don’t flame me too badly, I’m just trying to do some research for getting a lift. So I was thinking rather than dropping the back of the transfer case why don’t you raise the front of the engine? It will produce the same result although eventually you’ll run into a clearance issue, although I don’t know what will hit first.
Yes, a MML will provide some correction to the rear driveline angle. After about 2.5-3” of suspension lift, you need a significant TCase drop or an SYE and DC, the latter being preferable.Just thinking out loud here, and I’m new to jeeps so don’t flame me too badly, I’m just trying to do some research for getting a lift. So I was thinking rather than dropping the back of the transfer case why don’t you raise the front of the engine? It will produce the same result although eventually you’ll run into a clearance issue, although I don’t know what will hit first.
