Jesse Jaynes
Hi new to this thread i havea 04 tj with a 4in lift and a sye it has a tcase drop already installed is it really necessary
Highly unlikely. Do you have adjustable control arms to match the SYE and double cardan rear driveshaft?Hi new to this thread i havea 04 tj with a 4in lift and a sye it has a tcase drop already installed is it really necessary
I have the double cardan rear driveshaft but no adjustable control arms it is a skyjacker 4 inch liftHighly unlikely. Do you have adjustable control arms to match the SYE and double cardan rear driveshaft?
Whoever installed that DC rear driveshaft should have also installed adjustable length control arms, at least the uppers on the rear axle. They're required to raise the rear axle's pinion angle to match the requirements of that type of driveshaft.I have the double cardan rear driveshaft but no adjustable control arms it is a skyjacker 4 inch lift
Skyjacker. I see.I have the double cardan rear driveshaft but no adjustable control arms it is a skyjacker 4 inch lift
I will have to look again but i am positive they are not adjustable i bought the jeep the way it is i plan on converting to a long arm kit soon possibly building my ownWhoever installed that DC rear driveshaft should have also installed adjustable length control arms, at least the lowers on the rear axles. They're required to raise the rear axle's pinion angle to match the requirements of that type of driveshaft.
The top drawing shows how the pinion angle must to be set for a double-cardan (aka CV) driveshaft. The bottom drawing shows how Jeep set the angle for the OE conventional driveshaft.
There are NO bolt-on long-arm kits that I'd install. Having done one and ran it for 5-6 years, I learned they don't work as well offroad as a good quality short-arm does. All my previous TJ's long arm suspension did better was the get hung up on rocks far more easily than my present Currie 4" short-arm suspension does that otherwise outperforms it in all regards,I will have to look again but i am positive they are not adjustable i bought the jeep the way it is i plan on converting to a long arm kit soon possibly building my own
Good to know i will post pics after workThere are NO bolt-on long-arm kits that I'd install. Having done one and ran it for 5-6 years, I learned they don't work as well offroad as a good quality short-arm does. All my previous TJ's long arm suspension did better was the get hung up on rocks far more easily than my present Currie 4" short-arm suspension does that otherwise outperforms it in all regards,
The only time you can make longer-than-stock control arms work is with custom installations with a lot of trial-and-error. The best current suspension that has longer control arms is Savvy's mid-arm suspension which even it requires significant expertise to install properly.
All of these pics show different times my previous TJ's long-arms were hung up on rocks.
View attachment 52141 View attachment 52142 View attachment 52143 View attachment 52144 View attachment 52145
Whoever installed that DC rear driveshaft should have also installed adjustable length control arms, at least the lowers on the rear axle. They're required to raise the rear axle's pinion angle to match the requirements of that type of driveshaft.
The top drawing shows how the pinion angle must to be set for a double-cardan (aka CV) driveshaft. The bottom drawing shows how Jeep set the angle for the OE conventional driveshaft. Drawings courtesy of Tom Wood's Custom Driveshafts.
Severe inexcusable brain fart, I did mean uppers. I'll go correct it, thanks for catching it!!Jerry, where you said “should have also installed adjustable length control arms, ‘at least the lowers’ on the rear axle.”......I was under the impression the uppers were better for adjusting pinion angle. Am I wrong about that?
