Dodge 5.9 Swap
Wojoe
Plainwell, Michigan
I have a wiring question-I have a 2000 Tj with a 2000 Dodge 5.9L swapped in with the auto trans. So I am merging my dodge harness to my Jeep harness. How do I merge the coil wires? The Dodge has 2 wires, automatic shut down and ignition coil driver #1. The Jeep harness has 4 wires auto shut down and ignition coil drivers #1, #2, and #3. Do I only use the #1 drivers from both harnesses? and don't do anything with the #2 and #3 drivers from the jeep harness.
Thanks...Joe
Thanks...Joe
Mine is an older harness so it was only 2 wires.
Have you read thru this thread on Jeep Forum? It's about the best one out there with the most amount of information. Yes it's long but it's worth the read.
https://www.jeepforum.com/threads/wrangler-magnum-v8-discussion.1365878/
  • USA Proud
Reactions: Wojoe and RINC
