Last week was cold air intakes.Didn't we do this last week?
Bad decision. Not even championship level coil spring rock crawlers run without f/r antiswaybars. You won't notice the difference until it would have made a difference. Older leaf spring suspensions like YJs and CJs did fine without their antiswaybars but the TJ's coil spring suspension does not.Broke the bolt trying to tighten it up, so I took off the rear sway. No real difference. Maybe softer ride
Noticeable directional stability becomes extremely noticeable in an emergency maneuver or if you're on a tight-twisty road you're trying to keep your speed up on.... like a mountain road with cars behinds you.I actually tried my Jeep TJ with no rear sway bar. Little or no difference off road slightly less directional stability on the freeway
Only the rear, does not see the highway, 4.88 gears. 3200 rpm at 55mph. in town and local. My previous 2 vehicles both blazers I also removed the rear sway bar with no issuesBad decision. Not even championship level coil spring rock crawlers run without f/r antiswaybars. You won't notice the difference until it would have made a difference. Older leaf spring suspensions like YJs and CJs did fine without their antiswaybars but the TJ's coil spring suspension does not.
It's your Jeep, run it how you want to. Oh, and what type of rear suspension was in your two Blazers? Coil spring or leaf spring? I dunno about yours but my Blazer had leaf springs in the rear.Only the rear, does not see the highway, 4.88 gears. 3200 rpm at 55mph. in town and local. My previous 2 vehicles both blazers I also removed the rear sway bar with no issues
Leaf, well it will stay off till i get the broken bolt outIt's your Jeep, run it how you want to. Oh, and what type of rear suspension was in your two Blazers? Coil spring or leaf spring? I dunno about yours but my Blazer had leaf springs in the rear.
Here is one way to objectively and safely do that. The state of Washington specifies this minimum safe handling test. An empty parking lot, a few cones or waste baskets, and ten minutes of time.There is really no accurate way to answer how your rig will do without it. I'd suggest that you try it carefully and see what it is like.
As I stated in previous posts in NY if you are in an accident regardless of whose at fault, even if you are stopped at a red light and some fool in a stolen car drunk of his a$$ hits you from behind, and you have removed suspension pieces from your vehicle you get tickets, fines and insurance hikes too. Yet 1 more reason everybody hates this state.
And if your the victim they check your suspension? The cops must know a lot about the 100s of different vehiclesWouldn't the same apply to any suspension modification, even just a lift?
There is always an idiot looking to make a name for himself. But yes, they do indeed check out the "victims" car too. The visible difference between hardware store bolts vs factory suspension bolts..... guy would be blind to miss it.And if your the victim they check your suspension? The cops must know a lot about the 100s of different vehicles
