the JKS also uses a drilled out frame side hole.If I were to go JKS, what do I do with my over sized frame side hole? That's my biggest issue at the moment.
To what size?the JKS also uses a drilled out frame side hole.
I was just about to try and find out, gimme a sec....To what size?
For some, yes. Many are not willing to pay twice the price for a Rock Jock. I'm not saying you shouldn't, just that some won't!Is there some dramatic price difference that stops one from just fixing it from the get go?
My JKS track bar on the frame side uses a bolt that's a smidge larger than 1/2-in, see if you can measure what sized hole is on yours, it might fit the JKS just fine.If I were to go JKS, what do I do with my over sized frame side hole? That's my biggest issue at the moment.
They have been fully aware of the issue for a very long time. They have not fixed the issue and continue to send out free replacement joints rather than use a quality joint from the start. Says all I need to know about them.A high quality rod end for the frame side is 50 bucks + wholesale in quantity. Does the price reflect that?
A smidge larger than 1/2" in a fractional drill index is 33/64's. I'm pretty sure they drill out to 9/16" to use a 9/16" bolt with that stupid small tapered sleeve, correct? FYI- that sleeve does exactly zero except add cost and complexity.My JKS track bar on the frame side uses a bolt that's a smidge larger than 1/2-in, see if you can measure what sized hole is on yours, it might fit the JKS just fine.
MOUNT ADJUSTABLE TRACKBAR TO CHASSIS BRACKET Using a 9/16” drill bit, enlarge the tapered mounting hole in the chassis rail bracket located on the driver-side of the vehicle.My JKS track bar on the frame side uses a bolt that's a smidge larger than 1/2-in, see if you can measure what sized hole is on yours, it might fit the JKS just fine.
Let's don't overlook the issue with a side facing rod end either. All the dirt, crap, gunk, water, etc. that lands on the ball gets moved into the race and wears it much faster than one with a horizontal bolt.They have been fully aware of the issue for a very long time. They have not fixed the issue and continue to send out free replacement joints rather than use a quality joint from the start. Says all I need to know about them.
That sounds right.A smidge larger than 1/2" in a fractional drill index is 33/64's. I'm pretty sure they drill out to 9/16" to use a 9/16" bolt with that stupid small tapered sleeve, correct? FYI- that sleeve does exactly zero except add cost and complexity.
No problem with mine.Also, take the weight of the rod end and give it a shake. See if it clicks.
JKS is 9/16” the RE, MC and Currie were the only ones I found to be 5/8” so to replace without reworking the frame mount . These were the choices $125 vs $185 vs $425.A smidge larger than 1/2" in a fractional drill index is 33/64's. I'm pretty sure they drill out to 9/16" to use a 9/16" bolt with that stupid small tapered sleeve, correct? FYI- that sleeve does exactly zero except add cost and complexity.
That is generally a poor way to make decisions of importance.These were the choices $125 vs $185 vs $425.
Yes, but always a consideration. It does clear every suspension component, locates the axle side to side and my suspension travel is limited by short arm and shock length. So it checked all the boxes for me. The additional funds allowed me to buy one of your HD tie rods and flip kit .That is generally a poor way to make decisions of importance.
I'll have to measure my hardware tonight and see what I find.That sounds right.
Limited by shocks maybe. Definitely not limited by the arm length.Yes, but always a consideration. It does clear every suspension component, locates the axle side to side and my suspension travel is limited by short arm and shock length. So it checked all the boxes for me. The additional funds allowed me to buy one of your HD tie rods and flip kit .
I'll have to measure my hardware tonight and see what IThat sounds right.
I believe I'm at 5/8" but have to measure. I'm assuming the 185 is MC and the 425 is rock jock. What is the 125?JKS is 9/16” the RE, MC and Currie were the only ones I found to be 5/8” so to replace without reworking the frame mount . These were the choices $125 vs $185 vs $425.
Rubicon Express?I'll have to measure my hardware tonight and see what I
