Gorogergo
Thanks.I stand corrected. 7/32nd drill bit
Same project! Only instead of painting, I'm trying to vinyl wrap the half doors I just picked up. I suspect getting the hinges off will make the project much easier, and the final product look better when it comes to vinyl wrap.I had this struggle when I did my half door project. Never could get them off, also didn’t try a lot of the above. I just painted over them, thankfully doors aligned right.
Your picture isn't working and yes it's lefty looseyBefore I go any further, I just want to check: It's still "righty tighty, lefty loosey," right?
Uninspiring update: Heat didn't cut it. I'll give you three guesses at the objects in the picture below, but the first two don't count and no, I'm not regearing:
Looks like we'll be drilling them out, though given my experiences thus far, I may need vibranium drill bits.
well ain't that something...fixed the pic, thanks for the heads upYour picture isn't working and yes it's lefty loosey
Yeah with vinyl that may make a big difference! Good luckBefore I go any further, I just want to check: It's still "righty tighty, lefty loosey," right?
It sucks but even on the rust free jeeps I tinker on and tear down they are always a bitch so don't get down on yourselfwell ain't that something...fixed the pic, thanks for the heads up
I did! I swear! I heated the bolt itself, the bit before putting in the bolt, the bit while in the bolt, the backside of the bolt, the entire impact driver...nothing worked. Bolts (plural) didn't move and the new T40 bit broke.Should have tried the heat method recommended above first before drilling it. I'd try that with the rest of the bolts so you can get the hinge off and have hope of getting the one you drilled out with vise grips.
Just a simple propane torch with a pencil tipWhat type of torch do you guys use? A big Oxy/Acetylene torch is probably overkill for me and would probably last two centuries. Anything relatively compact and cheap that puts out enough heat to make large bolts smoking hot? I don't think I need something hot enough to cut metal...just enough to make stubborn bolts glow a bit.
And you thought the door bolts are a b- to remove, good luck drilling the easy-out to get it out!Then I stuck one of those spiral flute screw things in there...and borked it right in half
This is actually helpful - i've been avoiding putting the heat directly on the bolt head/paint out of concern for ruining the paint. But it looks like you're saying that despite head-on heat applied to the bolt didn't ruin the paint? That's incredible - this is the only thing I haven't tried yet, so I stand corrected, @Jerry Bransford !When I pulled my jeep apart, most of the torx bolts would not let loose with a 3/8 drive dewalt impact. Rather than hammering on the bolts till they stripped or broke, I took a propane torch, held the flame on the fastener head (from the exterior) and counted to 30. Every single one came out with no damage to the bolt and no damage to the paint. My jeep is from the Texas coast so there was plenty of opportunity for corrosion.
I'm using a big box tool store hand torch with small propane tank turned up to blue - it's worked for me in the past on other bolts, so hoping it does the trick this time too...What type of torch do you guys use? A big Oxy/Acetylene torch is probably overkill for me and would probably last two centuries. Anything relatively compact and cheap that puts out enough heat to make large bolts smoking hot? I don't think I need something hot enough to cut metal...just enough to make stubborn bolts glow a bit.
wish I could, but I don't have any welding equipment, unfortunately.Weld a bolt into the bolt head. This does two things, gets the bolt super hot and adds a new torque transfer device (hex head). After that came out no problem.
is a pencil tip different than the tip that typically comes with the tanks? It's smaller/narrower?Just a simple propane torch with a pencil tip
I didnt either at the time, but nice part of removeable doors is you can easily transport to a friends house!wish I could, but I don't have any welding equipment, unfortunately.
