Does anyone know which motorcycle mirrors that will fit when I am doorless on my Jeep TJ? Someone on here said they use them and they work great but I'm sure they have to be a specific size?
I'm not sure which Harley mirrors they were but I have these and really like them. They do vibrate some when on the road though. I've gotten used to them. I think I have about $15 in them.
Heat the OE bolts to get them out to install the brackets, the OE bolts are held in with Loctite that requires heat to loosen. Trying to force them out with an impact wrench or similar is not likely to produce anything but bad results like stripped out bolt heads.
Placing the tip of a soldering iron into the torx opening on the bolts will eventually get them hot enough to make their removal an easy process.
