It looks even better in person.Well that's a bit of a drive from El Dorado County to Fresno. I need you to change your picture every time I see it I still want to go with the Genright tire carrier
Ok I'll take one for the team and let you air down my tires while you race against the coyotes next run.I’ll have to test which is faster some day
Or I just do two on one side of mine while the deflators do the other.Ok I'll take one for the team and let you air down my tires while you race against the coyotes next run.
That's much better then the stock tank. Did you end up pushing the axle back any? You have 5" of room now correct?I finally ran a tank of gas out of the GR tank and the low fuel indicator comes on with a little over 2.5 gallons. I drove 6 miles to the station after it went off an put in 17.1 gals.
Why do you have to lose the tank?I love my GenRight extended range tank and am bummed I have to take it out. To keep at least 20 gallons of fuel in the Jeep I'm going to have to go with a fuel cell instead of a tank.
Are you putting the 30 gallon in your daughters TJ?I have a TeraFlex CRD 60 axle plus I moved it back 5" also. So the tank you have isn't suppose to work and I don't want to drop down to only 15 gallons for their next tank. So instead I'll run their 20 gallon fuel cell.
