This whole suspension thing is making me crazy, Chris. I've looked at OME, BDS, Savvy / Currie, Metalcloak, JKS Jspec and some of the lesser but still reputable lifts out there. The problem is pretty simple, and seems like it should have a relatively simple solution.
I have a light TJ SE. It's going to get a little heavier, but not much, as I add some gear to it. The roads that I travel on range from wash board gravel to dirt skid roads. I'm not a fast mover or a rock crawler, and never will be as it's not my style. But, I do need more suspension travel and more lift height. The lower spring perches are polished off from bottoming out the suspension and my gas tank skid has a bunch of scrape marks on it from dragging over some of the cuts, berms and crud. The little stock SE is going where I ask it to in fine style, but I'm beating it in the process. I really don't like doing that. I really think that all I need is 31x10.50's and a 2" lift. I very well could be lying to myself.
Then I start thinking that a winch would be nice to have sometimes, and bumpers, and an extra 5 gallons of gas, and more water, and, and and....I should just pack up the Suburban. So then I go back to keep it simple and light. But I still drag the gas tank skid and bottom out the suspension....
See what I have going on?
Yah, that's what I 'm afraid of as well. Put a bunch of money in a good 2 -2 1/2 inch lift and 31 inch tires and decide the jeep needs 33's and a bigger lift. Then I'm talking axles, gears, lockers, tummy tuck, a transmission... If I'm going there, then a chevy v-8 would be a nice feature.
Lots of positive reviews of the zone combo lift. And it's about $200 cheaper, all in, than the Jspec with the jks body lift and brown dog mml. The jspec is seeming to take less bump stop all the way around though and looks more balanced for suspension travel. I go bigger than the 31's and it just opens up a whole 'nother can of worms.
I do see your point though, and it's valid.
Sent from my SM-G900V using Tapatalk
Coming from someone who has been in your shoes, I have to tell you this: Go with the best of the best from the start and think big. It's so common for us Wrangler owners to assume that a small lift will be enough, but it never, ever is. We always want to go bigger so my suggestion is not to make the mistake I made and think about what the biggest size tire and lift you would want on your rig is. For me it was a 33" and I should have just done that to begin with and saved myself so much time and money.
Once I had the 31" tires on and the 2.5" lift it looked really good, but it simply wasn't enough to satisfy me.
I've considered the metal cloak dual rate 3.5 front coils to replace the 3"zone ones after adding a winch and bumpers, but only to give me that 1/2" back.
I don't want to go a true 4" because I still drive this 80mph on the hi way and I want to keep it that way. If I want a dedicated crawler I'll buy a crunchy piece and Dana 60 it. But this has to be good everywhere. I think many of you are in the same position but desire more offroad capable rig. Trouble is..now you compromise the on road. Been there...done that...made a rig a horrible road ride.
I'd love some GOOD 3.5" front coils though..if someone makes them
What happens on the highway at 80mph? I'm assuming the rig is just a lot more squirrelly (for lack of a better word)?
It's been MY experience (YMMV)..........
Ok, did you read your kids "if you give a pig a pancake" ?
Story about the snowball effect. If you go taller springs then generally you go larger tire, you go deeper gearing, you limit speed...etc.
I say you as in anyone...
IMHO once you go 35s you've crossed that threshold of vertical balance due to spring requirements and gearing, that makes the TJ superior to all other Jeeps (and he'll all 4x4s) for on road handling AND off road capability. Again..JUST my opinion and preference. 35s are ideal for the TJ offroad and I wish I had them, until I reach the trailhead and shift back into 2wd and set the cruise at 80 on the hi way home
Oh wait... Is an SE a 2.5 liter? If so... Shit, that's going to be hurting for power with 33" tires and too much weight... At least I would think so.
Yes SE is a 4 banger, he def will be hurting for power with 33's. But .. At 31" on mine, it still seems fine. You might be hurting at top end, but it just might be feasible, as long as you don't expect 70mph on interstate.
