Hi,bro.
My Wrangler TJ 2004 4.0 soprts suddenly won't start and I don't know why, so I would like to get everyone's opinion on the cause.
I tried to start the engine this morning and heard a "click" as if the starter relay was going on and then all power went down.
The navigation system and other accessories work fine when the key is in the ACC or RUN position, and the battery voltage is fine.
After repeating ON-OFF several times, the meter continued to run as shown in the video.()
This movement occurs when the key is in ACC and continues even when the key is removed. It stops when the key is in ON or START.
I disconnected the battery ground terminal and left it for about 2 hours, but the situation did not change.
This is the second time I have encountered this symptom. The last time, the problem was fixed while I was looking for the cause, so I continued to drive the car as it was.
I apologize for not being able to write this in a clear manner, but I would appreciate any help from the senior members of the team.
