Has anyone ever experienced their fan blade rubbing on the shroud while wheeling? This week at hidden falls I got on a particularly cheek clenching climb and was pretty flexed out while repositioning for a better line on the way up my fan shroud started rubbing (I assume that’s what I was hearing) on the shroud. It only happened on this one obstacle and only happened when I was in a decent bind. My body mounts are kind of cracked and dry rotted could that be a potential cause? My motor mounts seem to be in good shape I can visible see a gap between the rubber and top of the mount but from what I’ve seen on here that’s normal. Anything else I should look for? I’m lifted 4” but it’s all suspension no body lift and I have an sye so motor and trans should be in natural placement.
