Those look like the Golden Stairs just past Golden Crack. No big deal on 31s wheeling my stiffened '87 Cherokee with factory Dana 44 rear, lockered 5sp which I dearly miss.
Rocker knocker, Pritchett
Just right for that LJ. Most just slide over to the left then go up straddling what's left. Years ago there used to be a 4 foot rectangular rock which assisted climbers going up the left. Video shows my son's LJ kicking that precious rock out and down as he got up. Since then techniques had to be changed. Your right turn at the top seemed strange believing that was the Golden Stairs knowing that a left is required there. Your video makes it look flatter than it is. Great shot!
What axle? If it's for the HP Dana 30 with Super 30 shafts you won't find a No-Slip or other lunchbox locker to fit, it's going to need a full carrier locker like an E-Locker.I appreciate all the suggestions and info from everyone!
@Jerry Bransford and @JMT , I haven't been able to find a 30 spline no slip powertrax. Any idea where I can find one?
well hell... a selectable locker would more than double the cost of this Dana 30. Is a Dana 30 even worth putting that much into or do I just get some good 27 spline axles the powertrax and call it a day?
The biggest for now with the 30/44 combo is going to be 35s. I have already warned the wife that if I start getting into all this to much the 35s won't last long and that is when it will get expensive.
If you have slightest inclination you’re going to 37’s or more, there’s no use messing with Dana 30, Dana 35, or Dana 44’s. Just go to Dana 60’s and be solid.
I have welded smaller projects but never something like suspension parts. That is part of the reason I was going to truss the Dana 30, practice in case I ever do go to d60s. D60s are more of an invest than my current plans and this way I can figure out what I need and don't need if/when I ever to upgrade while I put some cash away.
@Rickyd I was under the impression you didn't really need hydro assist til you went 37"+
