Hey fellow jeep owners! i'm new to the forum so bare with me!
I Just have some questions regarding my jeep and some issues I came across. Any help/Advice is very much appreciated.
2000 Jeep Sahara TJ 4.0 I6
Issue #
ONE: my clutch {recently} completely gave out/fried. I am currently dropping the tranny and I ordered the well known LuK clutch set on amazon, it was on a price cut for $93. I dropped the skid plate to find that 3/6 bolts had to be cut off and the bottom side of the frame that is pressed up against the skid plate has rusted through, the frame is sturdy on all other sides but how should I go upon fixing this? I do have access to my friends welder but I myself have never welded and i'm sure he will help me weld on reinforcements. I'm very mechanically inclined and can fix/rig a solution if I want but some opinions on what to do would be awesome.
TWO: I also dropped the gas tank to replace the fuel pressure sensor, while disconnecting wires and hoses the metal EVAP hose/system snapped. Would automotive heat shrink tubing be enough to reconnect the broken area? (obv. dis. it from the gas tank. it's not fourth of july.... yet
THREE: The last thing I have to disconnect to drop the tranny is the E12 bolt on the passenger side. Whats the best/most effective way to disconnect the SOAB?
FOUR: There is a black substance at the front of the tranny and U-joint connections of the front and rear drive shaft? what could it be?...
FIVE: I'm using a wire brush to get rid of surface rust on my frame, then using krylon rust tough enamel primer then a layer of rubberized frame undercoat I picked up, anything else I should do?
Thanks for any input
Issue #
