Fluid recommendations
AndyG
Because some other guys are perverts
Lifetime Supporting Member
Alabama
My 03 manual 4.0 Rubicon is about to be regeared .
Traditional dino type oil was recommended over synthetic by Allen's Off Road, said it runs cooler .
Got me thinking -
What is best for radiator, manual transmission , oil, transfer case , and anywhere else ?
Bonus question-if you paid a shop to change transmission fluid , would you expect to see tool marks in the Allen nut?
Thanks
Andy
Rad - HOAT coolant such as Zerex G-05.
Engine - 10w30 summer such as Valvoline, 5w30 syn winter such as Amsoil.
TC - ATF+4 such as Valvoline
Diffs - whatever weight your manual says, dino only. If you paid a lot for your gears I'd only run Torco or another high end oil.
Brake Fluid - Amsoil DOT 3 & 4 (which is basically a 5.1)
Steering - whatever the manual suggests, for late years ATF+4 such as Valvoline. For PSC mineral oil such as GM (not synthetic).
Reactions: Ephry73
What is psc
I don't want to say you should be able to see tool marks. Because sometimes you dont.
With that being said if you drain and fill plug should show some type of indication that it was removed and installed. You might have to get in there and look closely.
Reactions: AndyG
