This subject comes up every so often and I suspect leaves most with the opinion they started with. What I find questionable though is throwing around subjective terms in an objective fashion. Terms such as best, stronger, much weaker, serious off-roader, etc. while appearing objective they nonetheless rely on anecdotal evidences or matters of opinion in support of the claim made. With the exception of adding points that could potentially get hung up on an obstacle, frame mounted sliders have not been shown to be inferior when comparing quality design and materials.Any opinions on frame vs body mounted sliders?
https://www.amazon.com/dp/B00IS93CGE/?tag=wranglerorg-20
vs
https://www.amazon.com/dp/B00ISA3GDW/?tag=wranglerorg-20
Every design has its limitations and/or trade-offs most often centering around form, function, workability, and cost. For instance Graphene, I believe, is the hardest man made substance known at ~ 200x that of steel. However, at ~ 1K per gram, for high purity material, makes the cost of a 30lb slider over 13M. Plus Graphene is not easily workable at present into structural components except in methods used today as in the layering of graphite.
However, quality (a subjective term) frame mounted sliders can withstand a lot of punishment see this vid from 4x Innovations and should not be considered inferior to tub mount versions in terms of strength in my opinion. I have yet to see a like test of tub mounted sliders.
So my advice is to begin with your intended use and work from there. Why expend $600.00 when the need is met with a $200.00 product?
