I thought the general rule of thumb was the oil level should be right at the fill hole?
For stock differential covers and relatively normal pinion angles that is true.
All stock height wise here, although I have a JKS 1.25” body lift sitting in the garage I got the other day.If you have a lift or rotated the pinion up (tummy tuck) you need to put the factory amount through the vent tube instead of filling it up to the plug.
Just fill to the plug then and you’ll be solid!All stock height wise here, although I have a JKS 1.25” body lift sitting in the garage I got the other day.
Should be fine as it sits then, thanksJust fill to the plug then and you’ll be solid!
Nope. Overfill the front differential and the oil pushes past the oil seals out the tubes and makes a mess.
Every. Freaking. Time. You. Drive.
Both of my pinions are a good amount higher than stock, especially the rear. That means the fill holes are lower than they ordinarily would be.I thought the general rule of thumb was the oil level should be right at the fill hole? I checked my 44 rear the other day and it was pretty much right below the fill hole. I thought that was good? Otherwise I’ll fill it up. Don’t wanna trash my rear
Thanks BBR, I do have 4" lift with some pinion rotation, no TT. There's confusion on what factory amount is, ranges 1.27-2.0 qts. When I put in 2 qts it's at bottom of filler hole, lolIf you have a lift or rotated the pinion up (tummy tuck) you need to put the factory amount through the vent tube instead of filling it up to the plug.
Look at your factory service manual. That will take away the confusion.Thanks BBR, I do have 4" lift with some pinion rotation, no TT. There's confusion on what factory amount is, ranges 1.27-2.0 qts. When I put in 2 qts it's at bottom of filler hole, lol
JJVW, wish it was that easy. That says 2 qts. Our forum says 1.375, thanksLook at your factory service manual. That will take away the confusion.
No one had mentioned that an overfilled diff will self correct through the breather vent.
Front or rear?JJVW, wish it was that easy. That says 2 qts. Our forum says 1.375, thanks
What does the factory service manual say?It's my front. There's agreement on 2 qts for rear
Is there enough pressure to overcome the vent?
I don't know anything about about pressure or vents.
Your diff housing has a vent.![]()
