For those considering insulating your garage door - Do it!
Aluminum garage doors are a serious heat/cold sync!
I insulated all the walls in my garage and held off on the garage door for a year or more. I still felt a chill in the garage - even though the insulated walls made a big impacts.
I went with 1" Polystyrene Board Insulation for the garage door. Lowes #15358
https://www.lowes.com/pd/Common-1-i...ded-Polystyrene-Foam-Board-Insulation/3365576
Installed this a couple years ago and it make a huge impact to the overall garage temp!
Today:
40*F outside
Temp on the insulation:
Used the laser on the print to minimize reflections.
Temp on the aluminum door that is carrying/radiation temp from outside:
About a 5* difference radiating into the garage.
I've felt a difference with the door insulated compared to just the bare doors.
I did re-calibrate the garage door springs for the added weight but it was maybe 0.5-1 turns on the spring so not too much added weight.
Encourage anyone with an insulated garage to think about this. Aluminum garage door is a huge weight radiator into the room...
Today:
40*F outside
