I have a 1997 TJ with a Currie Enterprises Transfer Case Conversion Kit CE-9069T and what seems to be a Rubicon Express yoke adapter and driveshaft (RE1807). I am not the original owner so I am digging all around trying to find a rear seal for the Tail end of my transfer case. I am not sure the seal I removed and am holding is the original kit seal. I thought mine was a RE Hack-N-Tap at first, but when you look closer at the shaft it is machined not drilled and tapped by hand. So I dug around and found the Currie kit that looks exactly like my setup. I just cannot find the replacement seal. When I look at the auto parts stores and part specs they do not line up to the measurements I am getting with my calipers.
Here are the measurements:Outer Diameter: 2.568"/65.2 mm
Inner Seal Diameter/Shaft Outer Diameter: 1.69"/43 mm
Thickness Outside: .475"/12 mm
If anyone has any insight it would be greatly appreciated. Another member posted something about a very similar setup last year, but got very little response.
