Just want to post about a Seat Riser Kit. My daughter is 5'2 and the sun visor doesn't help at the factory seat height. So I decided to install the 2 inch Supreme Suspension riser kit. I must say what a difference. Almost makes me feel like the whole Jeep Wrangler has been lifted.
The only issue with my install was that one of the bolts from Jeeps factory build, was a cross threaded bolt and I had to tap it.
The install besides that would have only taken half hour per side.
One warning is if others that drive the Jeep are over 6 feet tall, the tilt wheel won't get the steering off you legs.
Second the street signal lights, if your too close will be out of view. You will have to lean down to see the red and maybe yellow.
Otherwise the kit is easy to install and very sturdy.
Just wondered if anyone else has used a seat riser kit?
