My TJ recently developed a noticeable clicking noise, only at low speeds. Once you hit around 10mph it goes away. At first I thought it was a transfer case/transmission issue. After reading more and poking my head under the Jeep, I’m thinking it might be a driveshaft (U joint?) issue because if I manually turn the driveshaft that seems to align with the sound I’m hearing.
It happened in the past when I used 4H in the snow and the clicking started when I went back to 2H but then went away over time.
Linked is a video of the noise, then I stop and switch to 4H and turn a little bit and it sounds like there’s something broken/moving somewhere.
Any thoughts/things to try would be greatly appreciated.
https://vimeo.com/852010363?share=copy
