Great write up and images. Thank you for taking the time to post your project.
Thank you and you're welcome!
.... They're currently sporting whatever tune comes on them from the factory. If anybody has a shim stack they'd suggest I run (at least to get by) I'm all ears. I'll eventually road trip to the west coast for a proper tune.
If you had to guess (and if you don't mind my asking), how much money do you think you will have in this build by the time it's done. It's absolutely euphoric to follow the progress... but it can't be cheap, that's for sure.
That suspension setup is the stuff of dreams!
I have absolutely no idea how much money or time I've put into this build so far. While some individual pieces are pricey (for example, coilovers and axles) I find that it's the small bolts, brackets, and fittings that really add up.
For me this build is partially about the challenge of it and I enjoy eking out that last 10% of performance that takes 90% of the time. And doing so results in a certain refined finesse that can't be obtained in any other ways.
I have to assume you're going to do some serious wheeling in it when you're done with the build?
I feel you on the little stuff. Every time I take a trip to ACE Hardware to pickup bits and pieces (usually bolts and such), I'm always amazed by how quickly that hardware adds up. It gets expensive... fast.
For sure. Especially the large bolts amaze me with how much they cost. Want a handful of 1/2" grade 8 bolts? Better stop at the blood bank on the way and sell some plasma.
I do plan on wheeling this rig fairly hard and will be driving (driving, not towing) it across the country for various trails and trips. I still enjoy scenic easy to moderate trails and rock crawling is the real drug. I haven't done any go fast desert yet but I am excited to cut my teeth on that too once my Jeep is together.
Yes, I picked some up recently and it was something like $4 per bolt! It makes you appreciate the fact that most of these companies (i.e. Savvy) include the bolts in their kits. Most people don't account for how much those things cost on their own.
That's cool that you'll be driving it instead of towing it. I'm curious how it's road manners will be after all the work done. I can't imagine they'd be bad, but at some point that 4.0 may need to be replaced with a bigger power plant, especially for those highway trips, right?
Will the solid axles front and rear be ideal for go-fast desert stuff? I was always under the impression that those desert built rigs were better off using IFS in the front and solid axles in the rear. Of course I suppose you don't really have a choice there since putting IFS in the front of a Wrangler would probably be both pointless and incredibly expensive.
I'm just not sure how two solid axles would handle those washboard surfaces at high speed.
The steering is based on a design perfected by Blaine (great examples here: http://justaddrocks.com/Steering Pictures/steering.htm). I expect the road manors to be as tight as stock and the ride quality to be better — I am anxious to see how those points actually turn out.
I am boosting the 4.0L and my build is extremely light (I'd guess sprung weight will be right around stock weight if not less). I know I want to eventually do an engine swap I also know that I'd be unsatisfied without swapping the tranny and transfercase at the same time. I also know that I'll want to make that engine perform too and like the rest of my build not settle. Maybe aim for 600HP?
Solid axles are not ideal for go fast. I'll only be dabbling in it... for now... Plenty of Ultra4 cars have proven that while not ideal you can do desert racing with solid axles just fine. Obviously you're not going to see the next baja champion on solid axles but for an all around build I think solid axles are great.
That steering setup looks really, really amazing. I'm curious to hear how it handles with that setup once all is said and done.
My old TJ Rubicon was boosted with a supercharger. I was running 8 psi and it definitely transformed the 4.0 to the point where it felt like the power had almost doubled. I ended up selling that supercharger to Blaine (well, he traded me for some stuff actually) before I sold that TJ Rubicon and got my new one, which coincidently I've also decided to boost as well.
But with as much money as you've put into yours (and all the choice parts), I think that there's no way I wouldn't be swapping in a V8 at some point. One of those LS motors would easily be good for 600hp, and you could pair it with a new transmission and transfer case (Atlas?) at the same time. At this point it's basically just screaming for a V8.
I hadn't actually seen anyone do desert racing on solid axles, so that's pretty cool to watch! That Ultra4 is absolutely awesome. I've always been impressed with those sort of desert racing rigs. Watching them race is such a blast. What I wouldn't give to have one of those!
You ought to try and make the next KOH. If my build is reliable by then I'll be trying to make it (maybe you can host a forum meet up or have a booth?). I've never been and have only watched the live stream.
Yeah, I know I should do a V8 swap but I miss driving my Jeep. And with the faint knowledge I have of even just the exhaust routing alone that will need to happen I think the engine swap could end up taking me another summer to do. I am setting up the fuel cell to port right into a V8 though. Someday...
My favorite part about this is that it's meant to be street driven as well as off-roaded.
I see a lot of guys get to this level of build where it becomes completely impractical to be driven on the street. I'm not suggesting you'll daily drive it, but driving such a beast on the street at all is awesome in my book.
