How did you determine the sizes/thickness of the plate used for the mounts and gussets? Looks kind of small to the untrained/unfamiliar eye... Wondering if there’s a method to it all or just eyeballing it.
Any idea if the frame needs to be beefed up for the weight of then engine. Read that Jeep did something of the likes when they swapped in the bigger and heavier V8 in their Wrangler 392.
I had it in my mind to make them from 1/8" so as to prove a point that big thick mounts aren't necessary. I added the gussets to further strengthen them and then sent the design over to a much more experienced friend who agreed that the design should hold up well with 1/8". 9/16" bolt will also be torqued to around 110ftlbs which gives considerable strength to the bracket by adding a "top" to it.
The LS engine is much lighter than the weight of the inline 6 so no concerns as far as weight go. However I have had concerns about the torque of the engine wanting to rip apart the Jeep. I'll be using a big thick belly skid which will add torsional strength to the frame and I also have the hoop spreader that goes over top of the engine. Looking at other swaps this seems to hold up well.
